10-30-2021 12:33 PM
The power cord for my Nest Wifi Router H2D was cut and I need to order a replacement. That said, none of the results that I found searching eBay, Amazon, Walmart… or Google, were entirely convincing with regard to authenticity. I’d like to replace it with an OEM power cord without buying an entirely new router.
Is it possible to order a replacement directly from Google?
Thank you!
10-31-2021 12:38 AM - edited 10-31-2021 12:41 AM
Any power cord with the same connector (barrel), same voltage, and same amperage or more (yes, more amperage is OK, the device will only take what it needs), will work.
I don't think you can order replacement power supply/ adapter from Google directly.
Related threads:
Related threads:
11-02-2021 10:43 AM
Thanks @Anonymous.
I ended up ordering: AC Charger Fit for Google Nest WiFi, Nest Mini Smart Speaker Wall Power Supply Adapter Cord https://smile.amazon.com/dp/B09CD5NJKR/ref=cm_sw_r_cp_api_glt_fabc_7KDG4T1Z8N8RRK12TMQ5
I’ll update this once I receive it and can comment on its functionality and quality.
11-05-2021 02:44 PM
Thanks for the update, giby.
If for some reason that doesn't work out for you, please let us know and we can look into other options. It looks like olavrb gave you some good direction, so thanks olavrb!
11-05-2021 05:56 PM
Thanks, Jeff!
I finally received the power cord, today. Minus the Google branding, it looks and acts exactly like the original power cord. Great price but terrible shipping.
11-09-2021 09:53 AM
Hey, giby.
Glad to hear that you got everything sorted out and working. As we have our resolution on this, I'll go ahead and close up the thread. If you have any needs in the future, please feel free to open up a new discussion and we'll be happy to help.
Thanks!
