03-29-2023 07:22 PM
My Samsung TV and Playstation 5 will not connect to the internet when wired in and going through a Netgear switch. The switch is unmanaged and this worked with both my old Nest Wifi and Orbi. This seems to be something that I read elsewhere on the forum and on the internet, but I don't see where this has been solved. I purchased a brand new switch because I thought the switch had died, however, same behavior. There is something wrong here and I'm hoping that someone can provide some guidance on this. These devices cost too much to have to constantly spend time factory resetting them just to get them to do basic networking.
03-31-2023 06:52 AM
What exact switch? Brand and model. Even though it's unmanaged, and even though it worked with other equipment, it might have conflicting features.
04-02-2023 08:15 PM
@olavrb, appreciate your helpful response.
@darrindyson, chiming in to ensure everything is good here. Have you had the chance to see olavrb's response? Let us know if you have any questions.
Abi
04-06-2023 05:21 PM
Linksys SE3800V2. I had the original Nest Wifi and it worked fine. Had eero WiFI and it worked as well. Was working fine initially and just stipped at some point.
05-09-2023 07:39 PM
Hey there folks,
Thanks for the help, @LovelyM.
@darrindyson, my apologies for the late reply. Could you try connecting your Samsung TV or Playstation 5 directly to your Nest Wifi Pro and check if the issue persists? I’d like to isolate the issue further. I’ll wait for your reply.
Abi
05-13-2023 09:05 AM
No I can't connect it directly. Even if that were to work, that wouldn't be ideal. It makes no sense that this just stopped working with no changes. I moved on an bought a different mesh wifi system. The performance and connecttivity issues just aren't worth continuing with this system.
05-15-2023 08:07 PM
Hello again darrindyson,
Thanks for the update. We're sad to see you go. If ever you change your mind, we're here to help.
Abi
05-19-2023 05:29 PM
Hi darrindyson,
I know it has been a while, but please inform me if you still need a helping hand.
Lovely
05-20-2023 11:48 PM
Hey everyone,
Abi
05-13-2023 08:30 AM
Hi darrindyson,
Checking in should you have any concerns or questions you need help with. Let us know by replying to this thread.
Lovely
04-06-2023 04:52 PM
Hello darrindyson,
I'm checking in to see if you were able to do the steps above. I want to make sure everything is covered on your end, so let me know if you still need help.
Lovely
