02-04-2024 08:43 AM
Hello
I'm having trouble with my internet speed and I dont really get any good answers. Google Nest is connected to modem, and tests are showing that download/uploadspeed is around 500/500, like it should be. But however I only get between 20-40 mb/s as real download speed. Google Home is also showing me a current/realtime downloadspeed at below 20Mb/s at the the same time as the speed test in google home is showing 500/500. What can i do? Is something broke?
02-25-2024 04:00 PM
Hi KjBread,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet service provider (ISP)? Which Google/Nest router are we working with? What device are you using to set up your network (iOS or Android)? Do you have the Internet on your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
