Nest wifi point - adjust bottom light brightness - setting gone from Google Home app?
imikeyb2
When I got my Nest Wifi Router with 2 Points around a year ago, I was able to go into the Google Home iOS app, choose a point, go into its settings and adjust the bottom light brightness that best fits the room setting.
just as these basic instructions are listed:
Adjust the brightness of the status light
  1. Open the Google Home app
  2. Touch and hold your device's tile.
  3. At the top right, tap Settings imikeyb2_3-1665782311595.png. For some Wifi points, you might also need to tap Lights.
  4. Under 'Status light brightness' or 'Bottom light brightness', adjust the brightness of the device's light.
BUT - now that is no longer true, and Ive moved my points and cannot adjust the brightness.
Was this removed in an update?  there is no slider there anymore.
Under "LIGHTS"
I only have, two basic on / off options....
I apologize if this is answered somewhere else, or otherwise common knowledge but I have searched and failed to find a positive answer.
Thanks!
bananaslug79
I definitely see this change, no slider anymore but there are three options to choose from: Off, Low, High
I'm using the Google Home app on Android, I see this both with Nest Wi-Fi routers and the points.
bananaslug79
Thanks, I do see the status light OFF (which leave the mute bottom light dim) then LOW (which my girlfriend says is too bright still) and then HIGH (which is way too bright).  I was really loving the slider, I could have it on… but just barely so it was “glowing” but not bright enough to be a distraction 😕
*OFF is the closest I can find to the old setting I had.
Thanks for the reply/confirmation
Jhonleanmel
Thanks for helping here, @bananaslug79
@imikeyb2, I hope you've got the answer you're looking for. We're always looking for ways to improve and we'll take it as feedback.
I also suggest that you send feedback by following this link. Let me know if you have other questions or concerns, otherwise I’ll be locking this thread after 24 hours.
Mel
