10-26-2023 09:56 PM
So I have been struggling with this forever and I want to have all my points be wired backhaul.
My setup is Rogers Modem(bridge mode)---->Google Nest Pro 1--->unmanaged switch----->Google Nest Pro 2
Then The other points are wireless.
I have gotten this to say that it is wired before but it eventually switches back to wireless in the Google home app settings for the point.
I have tried different points different cables and no switch inbetween. What is going on??
I'd like to figure this out before I wire one out to my garage and loft apartment.
Thanks in advance
11-14-2023 12:59 PM
Hi unlikely_event,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? What device are you using to set up your network (iOS or Android)? Do you have the Internet from your modem? Have you experienced any outages?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
