11-10-2023 11:39 PM
Hey All,
Exactly the same as the issue found here.
Normal speeds when first starting the Google Nest WiFi is 100/20. After a certain amount of time, speeds become 100/5 and a restart of the device is required to get speeds back to 100/20.
After going through all troubleshooting steps by myself and with support, it was suggested to turn Nest WiFi Cloud Services off.
Turning Cloud Services off and monitoring for a few weeks fixed the issue, with speeds holding 100/20. Turning Cloud Services back on, speed drops to 100/5 within 48 hours.
However, turning Cloud Services off removes basic functionality of the device, like having no visibility on devices connected or being able to pin an IP address.
Having spoken to support to advise of the above, all they have done is blame my RSP for not supporting Cloud Services and have ignored my replies ever since. This makes no sense for multiple reasons, from the speeds working fine after a restart and the issue happening with 3 different RSPs (AussieBB, Exetel and More).
I figured I would make this post to both give a solution to others looking for a fix (even though it removes basic functionality) and in the hope someone at Google sees this and can finally look into a firmware fix for the problem.
I'll provide an update, if I ever receive one, but it seems at this point, Google have passed the blame and wiped their hands clean, ignoring my requests for support and escalation.
Bobbiie
11-14-2023 01:56 PM
Hi Bobbiie,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Which Google/Nest router are we working with? What device are you using to set up your network (iOS or Android)? Do you have the Internet from your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
