Nest wifi pro device management
Gherb72
Will there be a device management capability to come. To see what devices are active/ offline, pause Internet or access for kids, update notification, or security. Or even the ability to set desired por routers up as a router or a point.
I don't feel like I have control or awareness of what's going on with my network.
6 REPLIES 6
SteveyJ
It's already there in the Home app under WiFi.
Gherb72
Ah, thank you, there it is. I appreciate that!
Jeff
No problem, Gherb72. Is there anything else you might need or any other questions I could help you with?
Jeff
Jeff
Hi Gherb72,
I'm not sure if you're already familiar with the network monitoring and management found within Google Home, but the Nest WiFi Pro uses Google Home for management, just the same as Google WiFi and Nest WiFi do. If you have used either of those products, you should be familiar with Google Home's capabilities, but you can definitely see active devices, pause devices, and manage use on the network. Let me know if you aren't familiar with Google Home and would like to discuss any specific features found there. For now, here's a good overview of Google Home and how it integrates with smart devices and your WiFi network: https://goo.gle/2rjmbJe.
Jeff
Gherb72
Thanks Jeff, I appreciate that. I'm good for now. I just setup the Nest pro yesterday, so I'm getting to know it. I'll reach out of course if I do.
Jhonleanmel
@Jeff, thanks for the help here.
@Gherb72, awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
