05-05-2025 03:38 PM
Had the google mesh router for a couple years, and about 6 months ago added a second point. In the past month speeds have come to a crawl. I've had the ISP come out and do a service call, and confirmed no issues. When i test in the google home app i always get over 600mbps. But on individual devices speeds are rarely above single digits. Troubleshooting and resetting the network solve the issue temporarily, but it soon returns. I've read that a software update might have had some bugs in it, is there anyway to reverse the update? The performance is unacceptable, and looking to replace with a better product. But i also dont feel like i should bear the burden for replacing a product that failed due to no fault of my own.
05-08-2025 02:52 PM
Hi Paul311,
Thank you for posting in the community. I understand that your Google Nest router has been providing a low-speed connection to your devices for the past month.
To further assist you, I'd like to ask you a few questions to provide the correct troubleshooting:
Keep me posted.
Rusell.
a month ago
House is 2400 sq feet, 2 story, so 1200 each floor and each floor has a Google nest wifi mesh router.
Both points (all) are affected. I even tried swithing the points physical location with each other, nothing improved.
Do i use a modem router combo? Like an all in one unit? No, cable modem supplies internet directly to google nest mesh router via an ethernet cable.
Ther have been no recent changes to ISP. In fact as I said, I even had them come out and do a service call to confirm everything was good.
Currently devices connected to the network are 29, but at least half of those are idle at any time, or super low users (water heater is "smart" etc.)
Troubleshooting was touched on but included resetting the entire network, which improved everything for a few hours up to a day each time. Also switched the 2 points as mentioned with no results.
The latest update is now the wifi will get so slow that my phone will actually drop wifi in favor of cellular while im in the house 10 feet from the router. Cell coverage in my house is terrible, mind you, and part of the reason we rely on wifi. Note that this is wifi, not internet, as even when not on wifi i can still access the google home app, and running a speed test there shows over 600 mbps to the router, while at the same time connected devices are getting single digit numbers.
a month ago - last edited a month ago
Hi Paul311,
Thank you for the update. Here are some troubleshooting steps that I'd like you to follow below:
Keep me posted.
Rusell.
3 weeks ago
I changed the dns settings. Like everything else I've tried, it helped at first. Now back to normal. Sometimes a restart helps, other times it doesn't. But regardless the speed test between router and modem shows me getting above 600mbps to the router every single time.
3 weeks ago
Hi Paul,
Thank you for the information you shared. To move forward regarding this inconvenience, I'd like to collect some additional information. what speed are you subscribed to?
When performing the test, please follow these steps:
Bring all child points back online.
Keep me posted,
Rusell
