03-16-2023 06:28 AM
I dont know if anyone has the same issue but after a couple of year working perfectly I now have a connection speed issue with my mesh. After aroubd 24hours the speed slowdown considerably and I had to reboot all mesh to make them work at full speed again. This is not very convinient. I trested my internet provider router directly with my computer in ethernet and speed is consistent there.
Does anybody else ecxperience that and managed to find a solution for remediation?
Thanks a lot!
03-19-2023 08:02 AM
Similar issue here - on Feb 18 I was pulling 320Mbps, on Feb 20 it dropped to 90mbps. haven't been able to get to get those speeds back. Tested modem and the modem is pushing 360mps.
03-19-2023 11:08 PM
Thanks for posting — let's see what's going on.
A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? How many devices are dropping from the network? Also, do you have any paused devices?
Give these steps a try:
Let us know how it goes.
Abi
03-22-2023 11:27 PM
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions ― we'd love to help.
Abi
03-23-2023 02:18 AM
Abi,
It's still an issue. The only thing I haven't done yet is the factory reset. If that's the only step I have left, then I will do that next.
Thanks
03-24-2023 05:06 PM
Completed the factory reset and still have slow wifi. Modem is pushing 320mbps but wifi is only putting out 90mbps. Any other suggestions? I'd love to know what changed on Feb 19 to cause this.
03-25-2023 11:29 PM
Hello there folks,
I'm sorry to hear that you're still having an issue with your Google Nest Wifi. If the issue persists after doing all the troubleshooting steps, please fill out this form and let us know once you're done.
Abi
03-27-2023 07:26 AM
Update - a day after completing the factory reset, I received an insight informing me that the cable between the modem and router was underperforming (I'm paraphrasing). I replaced the factory ethernet cable and my speeds are back where they belong. I had not previously received this insight.
03-27-2023 11:24 PM
Hi again everyone,
Appreciate the update, @Davesac. Glad to hear that your issue has been resolved. Let’s monitor it for a few days, just to be sure it stays the same.
@Vipster, I’d like to check in and see if you were able to try the troubleshooting steps. Let me know if you need help with anything.
Abi
04-01-2023 10:14 PM
Abi
04-02-2023 04:53 AM
350/12 as of this morning. The cable was definitely the issue.
Thanks for your help!
04-02-2023 07:43 PM
