Replaced google wifi with nest wifi and can't change my LAN setting.
chauncythecat
I setup my replacement Nest Wifi yesterday.  The main router setup easy, but then I couldn't use either of my google phones (pixel 5 and pixel 6) to setup the points.  A legit 3 pack nest wifi system from Google would not setup with my google phone because google claims there is a bug with Google phones.    I fired up my old 1+ and setup the points after I figured out I had to download some google software called "device manager" that is evidently banned in North America.   It took me an hour to finally get the 2 new points, paired with my older 5 google wifi points, and everything is working.  Now to the issue,
For the last 3 years I've used Google Wifi with a LAN of 10.0.0.1  It has functioned without issue. I have a fairly large home networking setup, and I have countless devices that are set to use this LAN IP.
I can go into the google home app, click on wifi, go to the network settings, and no matter how many times I change the settings and click save, as soon as I reload the app it defaults back to 192.  I've tried my pixel 5, pixel 6, and 1+.  How is it possible that this bug exists?  Is there a work around for it?  I am not going to reprogram about 20 devices to use a different LAN.
olavrb
It's probably a bug with the Google Home app. It should work, it's even a guide for it:
I escalated this thread, up to Google to respond now.
I don't work for Google.
EdwardT
@olavrb, thanks for the help as always!
@chauncythecat, thanks for reaching out and I'm sorry to hear that you're having issues with setting up a custom LAN IP. I'd love to know more about this and I have a few questions:
  • Are there any changes on your network aside from the replacement Google Wifi devices?
  • Are you using a modem / router combo?
  • Are you using an Androind or an iOS device?
Edward
EdwardT
Hi chauncythecat,
Edward
EdwardT
Hi chauncythecat,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
