05-08-2023 08:50 PM
I’ve had a Google nest wifi for some time and have had it consistently slow my Internet speeds. I’ve had the ISP come over and perform diagnostics and Internet is coming in at 500mbps, but nest slowing the speed to the point where TVs get blurry and Internet becomes slow. The speed returns only when performing a speed test on Google home app or when resetting internet. The speed stays fast for about a day and then reverts. I’ve seen several posts on this issue, but none of resolution. This appears to be a product issue. I’ve done all basic remediations provided (setting preference, priority, reset, etc) and none of worked. Other users seemed to have gotten frustrated by posts and stopped responding. Is there any remediation for this?
05-09-2023 02:00 AM - edited 05-09-2023 02:01 AM
You can try unlinking your mesh and then linking it back (full reset)
Did you plug it in to your moden or router? You should plug it in to your modem
05-09-2023 05:44 AM
I will attempt a factory reset. The nest is plugged directly to the modem. I no longer have a separate router. The nest is functioning as the router/mesh. If this problem doesn’t get solved, I will be throwing the Google nest wifi out and going back to the ISP router.
05-09-2023 05:50 AM
There are multiple articles on the web about these slow speeds being a product/firmware issue.
https://www.theverge.com/2022/11/12/23454915/google-nest-wifi-pro-update-fix-slow-internet-speeds
05-09-2023 09:45 AM
spoiler alert, I did that and the issue persisted
05-10-2023 05:15 AM
maybe try updating the sofatware of the mesh?
05-10-2023 08:40 AM
Software updates happen automatically, but certainly during. A force reset. I’ve done a reset and have the same issue. Starts fast and slows down over time. Only way to speed it back up is through a speed check or restart. Definitely a widespread Google product issue.
05-12-2023 06:34 AM
how does one do that?
05-15-2023 06:42 PM
Hello folks,
Thanks for posting — let's see what's going on.
A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Also, do you have any paused devices?
Give these steps a try:
Let us know how it goes.
Abi
05-15-2023 08:42 PM
Hi AbigailF. I am using a modem from my ISP, with the Google Nest WiFi serving as the direct router. There are no pauses devices.
All settings and specifications were as you noted above, except the DNS server was set to automatic and I have now changed it to the custom IP addresses shown above. I will monitor it the next few days and see if it improves.
05-16-2023 06:15 AM
Abi, I've already done all of those steps. They've been repeated countless times on this thread.
And no modem, I am using Verizon Fios directly to google nest wifi, and I have the wifi turned off on the fios router. And no paused devices.
05-20-2023 04:55 PM
Hi AbigailF. I’ve made all the changes that you suggested. The main one being the custom IP address. I was optimistic that it would work but we are experiencing poor Internet speed again. We are back to daily resets. Any other suggestions?
05-21-2023 11:53 PM
I'm sorry to hear that you're still having an issue with your Google Nest Wifi. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Abi
05-28-2023 05:43 PM
@Johnnys, we got your form — thanks for filling it out. Our team will reach out to you via email anytime soon. Please continue the conversation there
@WasAFanOfNest, have you had the chance to fill out the form above? Let us know once done.
Kind regards,
Dan
05-28-2023 06:31 PM
Thanks Dan. Looking forward to a resolution!
06-04-2023 11:32 AM
Hello there,
Johnnys, from here on out, you can continue the conversation with our team via email. We appreciate your patience and understanding.
How are we doing, WasAFanOfNest? It would be of big help if you could fill out this form. Keep us posted.
Dan
06-05-2023 06:52 AM
I filled out the form just now
06-06-2023 08:14 AM
Hey WasAFanOfNest,
Thanks for submitting the form! We'll be reaching out to you via email soon and continue working on your concern through that channel.
Let us know if you have additional questions or concerns; otherwise, I'll close the thread after 24 hours.
Kind regards,
Lovely
