Speed tests
Rfrenchu
When I run a speed test from the browser on my desktop it only says I'm getting About 50MB a second. But when I check Google home using my phone it tells me I'm getting well over 300 why the difference
EdwardT
Hi Rfrenchu,
Thanks for reaching out. The speed that you're getting from the Google Home app is the speed that your Google Wifi is getting from your router. Just to isolate the issue, how is your desktop connected? Is it hardwired or is it connected to Wi-Fi?
Edward
EdwardT
Hi Rfrenchu,
Edward
EdwardT
Hi Rfrenchu,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
