04-07-2023 02:55 PM
Hey all,
I am using Nest WiFi Pro (6E) on the latest firmware available.
When I connect my iPad Pro to my Mac (OS Ventura 13.3.1) using Sidecar, I drop from speeds near 200-300 mbs down to 15-20 mbs. I confirmed that this only happens when connected to this display here are the steps to check and reproduce:
Has anyone else had this same thing occur? Any ideas for how to fix it?
I haven't seen any other articles about this in the forums, so sorry if this is a duplicate thread.
Thanks!
04-08-2023 06:53 AM
Hello @logdun
After doing a little research on this, it looks like this is a relatively common behavior when using Sidecar over WiFi in general. Apparently, it uses a direct peer-to-peer WiFi network between the Mac and the iPad, which means the Mac WiFi hardware has to switch back and forth between that connection and your WiFi internet connection, which reduces WiFi performance rather significantly. It looks like you may be able to use Sidecar via a USB-C cable connection, which would avoid the P2P WiFi connection. You could also keep your Mac connected to the internet via Ethernet, leaving the WiFi hardware dedicated to Sidecar. But, I don't see a way to make it use WiFi for both functions at high performance. Just to be clear, this does not appear to be a Google/Nest WiFi specific issue. I hope this helps!
04-08-2023 06:53 AM
Hello @logdun
04-10-2023 10:02 AM
Yes, thank you! I was suspecting as much, but this gives me the reasons behind why it is this way. I will let my team know.
04-13-2023 03:04 PM
Hey logdun,
It looks like MichaelP was able to provide a good explanation on things here, but I wanted to check in and follow up to see if you had any other questions or anything more I could help with. If there's more you need, just let me know.
Jeff
04-16-2023 07:40 PM
Chiming in to see if you still need assistance with this. Let us know if you have additional questions ― we'd love to help.
Appreciate you lending a hand, @Jeff.
Abi
04-17-2023 10:15 PM
Hey everyone,
Abi
