09-05-2022 06:03 PM
I have recently installed a Verizon 5g and wish to connect it to my google WiFi. I can get it connected but it only runs at 25mbs and the Verizon unit is 300 ( WiFi speed test)
I have gone through and done all the NAT, DCHP, DNS, radio disabling and everything else I can think of except turning on the IP PASSTHROUGH on the Verizon unit as it is harder to disable once turned on.
I can only get 25mbs when connected to the google pucks but get 300 when connected tot the Verizon unit. Any suggestions???
09-10-2022 11:21 AM
Hey Jdobbs,
Thanks for posting — let's see what's going on.
Are you using a modem/router combo from your Internet Service Provider (ISP)? What Ethernet cable are you using to connect your modem to your Google Wifi (CAT5 or CAT6)? Also, do you have any paused devices?
Give these steps a try:
Let us know how it goes.
Mel
09-13-2022 12:30 PM
Hey Jdobbs,
Mel
09-14-2022 01:09 PM
Hey Jdobbs,
Mel
