03-18-2022 07:46 PM
My nest point has very weak connection and errors when performing mesh test. Why is that? And how to resolve? When I choose my wifi connection in my device, should I choose the main router / nest point?
Thanks!
03-19-2022 05:58 AM
Hello @Beginner123
If the Nest WiFi Point is reporting a weak connection, it may just need to be placed closer to the primary Nest WiFi Router. They connect to each other using a 5GHz WiFi link, so for optimal performance, it needs to be no more than one or two rooms away from the primary. From there, it will provide both 5GHz and 2.4GHz coverage to more distant clients.
Your clients should only see one network provided by both the primary Nest WiFi Router and secondary Nest WiFi Point. They will decide which one to connect to.
03-23-2022 09:57 AM
Hi, Beginner123.
I just wanted to jump in real fast to see if you saw MichaelP's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
03-30-2022 02:41 PM
Thanks.
04-04-2022 02:30 PM
Hi, everyone.
Thanks.
04-06-2022 09:32 AM
Hi, everyone.
Thanks
