Whatsmyip.com and wan ip are different for nest WiFi pro
cjoshi
I am trying to setup DDNS for my synology NAS.
The issue is I am not sure which public op to use. The WAN IP is definitely not private but whatsmyip shows different public ip than WAN IP from router’s setting.
when I access use WAN IP for DDNS, I can access NAS from inside the network but not from outside. Although the public ip reported by whatsmyip does not work at all.
cjoshi
Hi, thanks for the reply. I did look for the double NAT earlier but that was not the case and I was at least familiar with the concept.
After a little bit of research, It turned out that, it was a CGNAT turned on by the the ISP. I was not aware of the concept of the CGNAT. However once I reached out to the provider to remove the CGNAT, all started working fine.
Also while exploring all this, I learned about your other suggestion of not exposing the NAS to the Internet. Yesterday I configured OpenVPN with some tight firewall rules and it's working like a charm.
Thanks, again!
olavrb
You might have what's known as double NAT; two inner networks, where the WAN IP obtained by Nest Wifi isn't your public IP, but a local IP, RFC 1918, received from your modem/router combo.
That said: It's not best practice to expose a NAS directly on the internet, consider other options like VPN or Synology QuickConnect (if you got a Synology NAS).
About Synology QuickConnect:
About hosting a VPN server on a Synology NAS:
I don't work for Google.
cjoshi
Thanks, again!
olavrb
Ah, CGNAT, forgot about that being an option.
Good to hear you're all set. 👍
