WiFi mash system problem with connection
PvA1
i have a 2000sqft apartment with a WiFi mash system. The Router and 3 satellites.
on a daily bases I can’t surf and don’t have connection to the internet! I’m connected to the WiFi network but I can’t surf or use the network printer. So I will unplug 2 or all 3 satellites and after a reboot of them, everything works fine!
any idea or advice?
Jaymerr
Yes, same situation. Router plugged directly to the modem. Randomly stops sending signal on a regular basis
Jhonleanmel
Hey PvA1,
I’m sorry for the inconvenience this may have caused — let's see what's going on.
Are you using a modem/router combo from your Internet Service Provider (ISP)? How many devices are dropping from the network? Also, do you have any paused devices?
Give these steps a try:
  1. Make sure that there is minimal to no interference (concrete, bulletproof glass, metal, mirror, etc.)
  2. Set a custom DNS at 8.8.8.8 on the primary and 8.8.4.4 on the secondary server. Hit the save/ floppy disk icon on the upper right.
  3. Unplug the power from your Google Wifi devices for 2 minutes.
  4. If the issue persists, try factory resetting your network.
Let us know how it goes.
Mel
Hey PvA1,
Mel
Hey PvA1,
Mel
