11-02-2022 03:01 PM
Hi all, trying to change my isp to Verizon. The 5g ultra wideband already has a router but I like my existing mesh network created with my google devices. I want to connect my google WiFi main router without an Ethernet cable (connect to the WiFi network created by the Verizon device, then use the secondary WiFi network created by the google devices). Is this possible?
11-02-2022 07:46 PM
Unfortunately it is not.
Your Verizon router cannot create a mesh network with the Google wifi devices you already have. The Verizon and Google devices cannot connect to each other as a mesh. You theoretically can connect the Verizon router via Ethernet to the Google device but it would creating a Double NAT situation that will stop all data traffic.
Two suggestions:
Personally, I have found that, like in option 2, buying your own modem is a lot better that using one of theirs, if available; they should have info on their site. Yes, it does require some investment initially, but they can't lock it down but to a certain extent since they don't own it. And as a bonus, I have always gotten better average speeds and usually higher speeds than what I subscribe to (anywhere from 20-50+ more than the "up to" highest speed). This is due to them not having as much control of the device which prevents throttling.
Sorry it can't be done but the above should give you some options to move forward with.
11-05-2022 11:05 AM
We appreciate your help here, @PatrickP_Viking.
@Tim109, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
11-08-2022 01:39 PM
Hey everyone,
Mel
11-09-2022 01:40 PM
Mel
