Wifi not connecting after pausing devices
Shane-F
I cannot get internet connection on devices which I have used the pause function on the Google home app.
I have unpaused all the devices and those devices which were paused are not connecting to the internet.
Multiple devices including Windows PC, Android phones are not working.
tajennifer
Hi Shane-F,
Thanks for the update. I'm sorry to hear about the situation that you are experiencing with the internet connection on devices on which I have used the pause function. I understand how frustrating it can be when things don't work as expected. But don't worry; help is here. In this case, I recommend that you try some steps for the app:
Reconnect Paused Devices:
  • Use Mobile Data, If possible, turn off Wi-Fi on your phone and use your mobile data to access the Google Home app. Then, resume the paused devices within the app.
  • Use Another Device, If you have another device with the Google Home app, try resuming the devices from that device.
  • Tether a Wi-Fi connection from your phone or use a mobile hotspot. Connect the affected devices to this temporary network and then resume them in the Google Home app.
  • Find Another Wi-Fi Network, If feasible, connect to a different Wi-Fi network (like a neighbor's or a public hotspot) and resume your devices.
2. Restart Network Equipment:
  • Power cycle the modem; power off your modem completely. Wait for 30 seconds, then power it back on and wait for it to re-establish a connection.
  • Power cycle the router; power off your router. Wait for 30 seconds, then power it back on and wait for it to fully restart.
3. Verify Network Settings:
  • Check Wi-Fi Password: Ensure you're entering the correct Wi-Fi password on all affected devices.
  • Forget and Rejoin Wi-Fi: On each device, forget the current Wi-Fi network and then rejoin it by entering the password again.
4. App Troubleshooting:
  • Uninstall the Google Home app from your device(s) and then reinstall it from the app store.
Please keep me posted and let me know how that goes.
Jenny
I have tried some of this stuff but will go through all that you have suggested and hope it works.
tajennifer
Hi Shane-F,
Thanks for your reply. I understand that you are going to try the steps provided. Please keep me posted and let me know if you have more questions.
Jenny
