Wrong setup code - Nest WiFi point
Anonymous
Not applicable
Hi all,
I've got a 2nd hand nest WiFi point that I'm attempting to connect to my existing Nest setup.
Factory reset, says it's ready for setup.
When I try to add to Home it instructs me to download Google Utility.
There is no QR code on this point so I have to add the setup code manually however whenever I try this it simply says 'Wrong setup code' and I cannot go any further.
I'm going to assume it's one of the first Nest models but I'm unsure as to why the code would not work.
Any suggestions? Thank you ☺️
Anonymous
Not applicable
I'll add that I've tried EVERY variation of the code on the bottom of the device. No luck. Home App is up to date - everything else is running perfectly through there.
