12-26-2022 04:51 PM
Im having issues connecting my Swann wifi cams to the nest, they only work with a 2.4mhz band and wont connect to the Nest mesh . I have successfully connected a Swann buddy doorbell to the mesh. Can I manually select the 2.4 network for the cams only and leave everything else to do its thing??
12-27-2022 01:54 AM
I'm having a similar issue but with multiple devices. You cannot manually select what network band gets put out. Google is supposed to be smart enough to know what each device needs in order to be connected.
Interested in how you got the door bell connected, is it in the 2.4ghz connection?
12-27-2022 01:54 AM
12-29-2022 02:33 PM
One of those it just connected moments, newer tech has more smarts I guess?!
12-29-2022 06:08 PM
I would be curious to hear how the initial connection to 2.4 GHz was achieved as well. I have multiple devices that can't connect. The device and the network should determine the 2.4 connection is most appropriate but that is not happening.
12-31-2022 09:01 PM
Thanks for posting ― let's see what's going on.
The Nest Wifi router and points uses the same name for both the 2.4 GHz and 5 GHz band networks. This means that the Wi-Fi network uses both radio bands. But keep in mind: while both bands can be used, the personal devices (a smartphone, tablet, laptop, etc.) will connect to only one radio band at any given time. Nest Wifi, Google Wifi, or OnHub attempts to select the band that will deliver the best performance for your device. Currently there is no option to manually disable either of the bands or to connect to them separately.
A quick question: what devices need to connect to the 2.4Ghz band?
Give these steps a whirl:
Create a hotspot with a mobile phone. However, 2 mobile phones are required:
Use the first device to create a hotspot (mobile phone).
How to set up a mobile hotspot:
Android
Go to Settings.
Tap the Network & internet option.
Select Hotspot & tethering.
Tap on Wi-Fi hotspot.
Set up the hotspot name and password the same as the primary network.
Choose the AP Band > 2.4 GHz band > Apply.
iOS:
Go to Settings.
Tap on Cellular. Tap the slider to turn Cellular Data on.
Under Cellular, tap the slider to turn Personal Hotspot on.
Tap the slider next to Allow Others to Join.
Set up the hotspot name password the same as the primary network.
To change the hotspot password, under Personal Hotspot Wi-Fi Password.
To change the hotspot name, go to Settings > General > About > Name.
Use the second device to connect to the mobile hotspot.
Disconnect all of the Google Wifi or Nest Wifi points from the power outlet.
Connect the device to the 2.4 GHz band of the hotspot with the same SSID and password of the current network (case sensitive).
Once connected to the hotspot, plug in your primary Google Wifi point or the Nest Wifi router.
Turn off the hotspot and check if the device automatically connects to the Google Wifi network.
Let us know how it goes.
Abi
01-04-2023 06:32 PM
We’d like to check in again in case you have any further questions or concerns. Feel free to reply to this thread and we’ll help you out.
Abi
01-06-2023 09:57 AM
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
