12-26-2022 03:26 PM
I purchased a nest Wi-Fi pro and want to set up the 3 mesh Wi-Fi points as wired access points. I have cat 6 outlets in all three locations that are feed from switch in basement (which is connected to the primary nest Wi-Fi router). Is there anything different I need to do when setting up the 3 satellite points from the google home app?
12-27-2022 01:36 AM - edited 12-27-2022 01:37 AM
Nothing different you have to do in the Google Home app. If wired correctly the units will detect that a wired backhaul is available. If you go to a given Nest Wifi unit in the Google Home app, it will say what backhaul it uses.
Here is a diagram showing how it all should be wired:
A common pitfall is having a smart/managed switch with conflicting features like loop detection (SPT, spanning tree protocol for example). If that's the case with your switch, make sure to disable such features. More on that:
12-31-2022 08:53 PM
@olavrb, appreciate your helpful response.
@KDCleason, chiming in to ensure everything is good here. Have you had the chance to try the suggestion above? If yes, how is it?
Abi
01-04-2023 06:32 PM
Hi KDCleason,
Abi
01-06-2023 09:56 AM
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
