01-22-2023 11:50 PM
I purchased the nest yale deadbolt for my mother. The existing door latch is 5" long. The two screw holes that mount the deadbolt to the door do not line up and the rod that actuates the latch does not work on the existing latch. I contacted yale but they say they do not manufacture a 5" latch so I am out of luck. Has any one else had this issue and found a solution?
01-28-2023 08:00 PM
Hi Silverado87,
I’m sorry for the delay. Thanks for letting us know. The recommended latch is 2-⅜” (60 mm) Position and 2-⅜ “ (70 mm) Backseat or 2-¾” (70 mm) Position and 2-¾” (70 mm) Backseat. Have a look at this installation guide.
01-31-2023 09:29 PM
02-01-2023 09:35 PM
Just checking in to make sure that you saw my response. I'll be locking this thread if I won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
