01-02-2026 02:18 PM
Hi. I just enabled the Smart hub or smart home feature option on my Android smartphone to try to connect my Bluetooth device to it. That is not an option I'm not sure what I was doing I just want to go back to only factory settings on my Android phone regarding the Smart home feature because I don't have any smart home devices that are able to connect to that feature I wasn't sure what it was I guess I got ahead of myself how do I stop it or disable it or go back to factory not on my whole phone just for the smart home smartphone home features? Thanks
01-06-2026 05:32 PM
Thanks for reaching out. There are 2 options to disable this feature.
If a "Home" icon appeared in the bottom corner of your lock screen:
If the feature still feels "stuck" or is asking you to set it up, you can reset the Google Home app, which usually powers this feature:
01-06-2026 05:32 PM
01-14-2026 10:17 AM
all user product delete
