Hub requirement for building matter virtual and physical device
fs1608
The code lab at (https://developers.home.google.com/codelabs/matter-device-virtual?hl=en#0) lists the requirement for "a hub, which is any Google Nest device that supports Matter, such as the Nest Hub (2nd generation)".
At this page: https://support.google.com/googlenest/answer/12391458?hl=en It is listed that following devices can work as a hub. Wi-Fi routers: Nest Wifi Pro (Wi-Fi 6E) Speakers: Google Home, Google Home Mini, Nest Mini, Nest Audio Displays: Nest Hub (1st gen), Nest Hub (2nd gen), Nest Hub Max
In the first link it is mentioned a nest device can act as a hub. In the second link, it is mentioned google home/home mini can act as a hub but I guess the home/ home mini is not nest.
So I was wondering whether a device such as google home mini or google home can work as a hub in the code lab. I guess google home/ home mini is not nest.
I am trying to find a cheaper option therefore I was wondering if home/home mini can be used as a hub.
Thank you very much for your support.
sipriyadarshi
Solutions Expert
Solutions Expert
  • This is just some kind of linguistic confusion. Google Mini works fine but it does not yet support thread. More information in this regard can be found here
sipriyadarshi
Solutions Expert
Solutions Expert
