2 weeks ago
I have 2 Google Home Max Speakers. My TV has RCA output (Red, White), so I connected an RCA to aux adaptor. I then connected an aux cable from the adaptor to 1 of the Google Home Max Speakers. It's working perfectly. I then wanted to pair my 2nd Home Max Speaker (using L/R Channel config in the home app) to the 1st Google Home Max speaker that's connected via AUX. Once I did that, there was a 1 second delay between audio on both speakers. Aux speaker 1 played first then paired speaker 2 played 1 second later, so it was way out of sync. This is for example, when I played a song on the TV. Is there any way to get rid of the delay? I know there is a delay setting in the home app. Or, is there another way to connect 2 home max speakers to the back of my TV even if it's mono vs stereo? My goal is to connect 2 home max speakers to my tv with a stereo config without delay. I'm trying to use them as a soundbar. As mentioned, I have 1 connected now via aux and it's perfect. I rather have 2. TY.
a week ago
Hi itpro4u,
Thanks for reaching out and for providing detailed information on your issue and — these are of great help!
You can try to do a sequential reboot. First, unplug your Google Home Max and TV for 30 seconds, then do the same thing to your Wi-Fi router to refresh both devices and your Wi-Fi signal.
Let me know how it goes.
Juni
Sunday
Have you had the chance to try the steps above? Let us know by updating this thread and the Community will be happy to lend a hand.
Alex
Monday
Hello itpro4u,
WeI want to ensure you are good to go, and everything is working properly. Please let us know if you are still having trouble, as we will be locking the thread in 24 hours due to inactivity.
Alex
