A way to set default devices for commands?
captenmasin
So I have a Nest Hub in my room, and of course I have a Google phone (Pixel 6 Pro)
Whenever I do the command "Hey Google, set an alarm for 8:30" for example, both devices light up, but it always sets the alarm on my nest hub (Which then makes it more of a pain to snooze or turn off because I have to actually speak from across the room to do it)
Is there any way to only set alarms on my phone?
Same with Google Home commands, I only want my nest hub to respond to those (otherwise I have to unlock my phone, but that's a whole other issue)
kiltguy2112
Turn off "Hey Google" on phone. Use the microphone on search bar on phone "set alarm for(time)". or Set up a shortcut to the assistant on your phone. Squeeze sides power button... Your phone may or may not allow shortcuts to assistant.
