12-11-2021 04:15 PM
Hello i have two nest audio speakers, but i tried to connect them to the pc using bluetooth 5.0 and the audio delay when playing media is insane i tried everything to mitigate this but it is imposible, the only way to see and listen something in the same frecuency is using only one speaker, but when you connect both speakers the audio delay comes again, any suggestion for this? i just wanted a good stereo sound, but right now I am regretting the purchase
12-11-2021 07:24 PM - edited 12-11-2021 07:24 PM
These are not designed to work as stereo speakers from another device over bluetooth. They were designed to be paired together in stereo mode, and then asked to play music from a source such as Spotify or YouTube Music. If all you want are pc speakers there a better less expensive option.
12-20-2021 04:21 PM
I was hoping to use these as a Bluetooth pair for tv. This is a pretty fatal flaw when watching tv/movies.
To make it even more frustrating, there is a delay control in the Home app … but it doesn’t offer enough control to actually fix the problem. It’s a legit 1 second delay.
12-26-2021 10:06 AM
Same here. Nest Audio works perfectly fine with a Bluetooth connection, except if I pair two of them. There is a long delay in paired mode.
I hope there will be a fix for this. I want to use the Nest Audio to listen to music as well as for watching movies on my TV. It should be the device for all needs in the living room!
12-28-2021 08:19 AM
Same delay problem with the TV audio using pair mode.
In Single mode works fine.
Please help us to solve
thanks
01-04-2022 11:27 AM
same issue here, two google home speakers connected into pair, to watch netflix or hbo go from PC.
The delay is terrible. Any idea when and if this will be fixed?
04-26-2022 02:22 PM
We hope you were able to get the help you need but if the issue persists feel free to create a new thread, and provide as many details as possible so that others can lend a hand.
Garrett DS
