09-04-2021 11:26 AM
I am having that crackling audio issue. Also the bar at the top that text appears on when you are giving voice commands is constantly popping down and when it does the audio stops each time. It is impossible to listen to anything. I have reduced the “hey google” sensitivity and this did not help. What do you suggest to remedy this?
09-15-2021 04:55 PM
Hi Sheri_d,
Thanks for reaching out. I am sorry to hear that you are having issues with your Google Nest Audio having crackling and popping noises. I understand your concern and would be more than happy to look into this issue. First, I have some questions to get a better understanding of the situation.
I appreciate your patience and look forward to your response.
09-20-2021 11:46 AM
Hi All,
It's been a few days since we have heard from you. Just checking to see if you have any other questions or concerns. We're here to help!
09-21-2021 10:24 AM
Hi All,
As I have not received any response, I'll go ahead and lock this thread. As always, feel free to start a new thread if you have any questions or concerns and we'll be happy to help.
