Google Hub max camera not connecting show offline
brownmiester
No way to add it online - seems it is migration problem
Its 5 months old and GOOGLE is VERY unhelpful.
offered to send me a replacement -- a " refurbished unit without a power cord" if i could send the other unit back to them
frances
Hello brownmiester
Thanks for reaching out. I apologize for the inconvenience caused by your Google Nest Hub Max camera not working. If you would like, we could try some troubleshooting steps.
  1. Open the Google Home app.
  2. Tap on Google Nest Hub Max, then Settings.
  3. Remove device.
  4. Factory Data Reset Google Nest Hub Max.
  5. Set up device and camera.
  6. Open the Nest app (switch to correct home/structure).
  7. Tap on Nest Hub Max camera and agree to terms (if prompted).
  8. Confirm if able to view live stream from Nest app.
  9. If able to, check the stream on Google Home app, and by navigating the Nest display.
Please let me know if it helps resolve the issue or not.
If the camera still does not work after these steps, then you will need to contact Google support again. Thank you.
frances
Hi All,
It's been a few days since we have heard from you. Just checking to see if you have any other questions or concerns. We're here to help!
frances
Hi All,
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
