Google Nest hub max Declining calls and not knowing the weather units set to
Gurky
For the past 6 months my Google nest hub max has been weird, any time someone will call on Google meet, it will decline the call, now I don't know if it has to do with the Google meet app but after I restart the nest hub, it seem to work perfectly fine, and another issue that bugs me alot is now it will say my weather in Fahrenheit even if it's set to Celsius, I fell it to use Celsius everytime and it says okay but then once again it will use Fahrenheit, please help
JuanCH
Hi Gurky,
Thanks for reaching out to the community! I understand that for the past six months, you've experienced some inconveniences with your Google Nest Hub Max: firstly, incoming Google Meet calls are being automatically declined, and secondly, the weather display consistently reverts to Fahrenheit despite being set to Celsius in your settings. I know how frustrating it might be when your Google Nest Hub Max doesn't work as expected. I'm here to help! To gather some more details, I'd like to ask the following questions:
  • After setting the weather to Celsius, how long does it typically take for it to revert to Fahrenheit?
  • Are there any specific actions or triggers that seem to cause the weather to change (e.g., voice commands, app updates, changes in location settings)?
  • Have you made any recent changes to your network, such as changing your Wifi password or router?
Keep me posted. I'll look forward to your response.
Juan
