07-10-2022 09:34 AM
Hi, google hub won’t turn on, I try to the reset hack with the two volume buttons but nothing works. Any suggestion?
07-18-2022 06:31 PM
Hey guys, the new cable came yesterday and it works now. Thanks for the help.
07-10-2022 11:50 AM
Are you using the original power cable and adapter that it came with?
Have you tried plugging it into a different power outlet?
07-10-2022 01:12 PM
Hi David, I’m using the original power cable. I tried unplugging and plugging it back.
07-10-2022 01:14 PM
Does it do the same thing if you try a different power outlet?
Is it connected directly to the power outlet and not via an extension cable?
07-10-2022 01:21 PM
Yes, I tried in different outlets and I doesn't turn on. Should I get another cable?
07-10-2022 01:28 PM
Worth a try with another cable that you know works. Can't hurt!
07-10-2022 01:44 PM
Ok, I’ll try that.
07-15-2022 04:46 PM
Thanks to @David_K for helping here.
It's been some time since this thread was updated. Does anyone here need assistance?
Muddi
07-18-2022 06:08 PM
I just wanted to check if anyone still need help here? Feel free to update this thread, and we're glad to assist you further.
Muddi
07-18-2022 06:31 PM
07-19-2022 01:18 AM
Hey Greg52,
Happy to hear that! It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Muddi
07-22-2022 08:06 AM
Hey Greg52,
I haven’t heard back, so I'll be locking this thread if we won't hear back from you again in 24 hrs. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
