Hearing static when using aux on Google Max speaker
Glennmarsh20
This issue just started happening. I have had the Google Home Max speaker for four years. I use it to play audio from my Samsung tv. I had to purchase an optical audio cord and converter to connect the devices. The speaker works totally fine when I cast audio from my phone. However, the aux will not work. I can’t hear any audio coming from the tv, only static. How do you solve this issue?
Alex_S
Hi Glennmarsh20,
Thanks for posting—let's further look into this. Have you used a different aux stereo 3.5 mm. (⅛ inch) cable to your Google Home Max? If not, give it a try. Also, try to put Google Home Max in different placements:
  • Horizontal placement: If the Home Max is placed horizontally, it outputs stereo sound. Most music is produced in stereo. Use this placement for a wider soundstage.
  • Vertical placement: If the Home Max is placed vertically, it outputs mono sound.
Let me know how it goes.
Alex
