10-09-2023 02:39 AM
I've raised a case about my home hub stuck in recovery mode and i'm unable to factory reset. i'm currently on Day 6 waiting for a response. how long does it usually take?
10-10-2023 10:46 AM
Hi Gar0504,
I’m sorry to know about what happened. Kindly share the case ID you have with our support team so I can check for an update.
Alex
10-10-2023 11:17 PM
Hi Alex.
The case number is 1-0056000034959
Coincidentally I had an update on the case not long after your reply
10-11-2023 11:37 AM
Hello there,
Oh, that’s good to know. I’ve also asked for a follow-up on your case with the support team. They will give an update on your case soon.
If I can help you with anything else on Google Home, let me know.
Alex
