05-14-2024 11:02 PM
Hello, how can I disable the Nest connection sound?
It makes a very loud chime, always louder than the music I actually play, and it is very, very annoying and stressful whenever I connect to the Nest Speaker.
I really need to disable this chime sound.
Please note that I'm not asking about start/end beep sound of Google Assistance, which is fine for me.
I have disabled both "Play start sound" and "Play stop sound" slide bars in Google Home - Nest Speaker settings - Accessibility.
Could it be a bug?
Please see my YouTube video that describes the annoying sound that I want disable:
https://youtube.com/shorts/L_y1uZCFsIk?si=CG0s7YPfn0epLGMF
05-14-2024 11:43 PM
o disable the Nest connection sound, follow these steps:
If you can't find this option in your app, refer to the Nest support documentation or contact their support team for further assistance.
05-15-2024 10:25 PM
Unfortunately, Nest app tells me to use Google Home app to control Nest Speaker. Are there different versions of Nest app?
I purchased Nest from Google product page, not Nest website.
05-23-2024 06:54 PM
Hi @dbdq!
I understand your frustration with the connection sound on your Nest speaker. It sounds like you've already taken some great troubleshooting steps, and I apologize for the confusion caused by the Nest app directing you to the Google Home app.
Here's the clarification:
There are no longer two separate apps for Nest and Google Home devices. Google has transitioned everything to the Google Home app. So, you're on the right track using that app to manage your Nest speaker settings.
Let's try to disable that connection sound:
Double-check Accessibility Settings: Within the Google Home app, ensure "Play start sound" and "Play end sound" are still disabled for your Nest speaker in the Accessibility settings.
Force Quit and Relaunch: Sometimes a fresh start helps. Completely close the Google Home app and relaunch it. This can clear any temporary glitches.
Update the App: Outdated apps can have bugs that newer versions fix. Check for updates for the Google Home app in your device's app store. If it's an update lets try uninstalling and reinstalling the app again.
Brandon.
05-27-2024 10:11 PM
Thanks for the reply but it still didn't fix the issue. More importantly, "Play start sound" and "Play stop sound" both work correctly because they are the acknowledgement sound played after "hey Google".
What I'm talking about is the Nest connection sound, that happens when I connect my phone to the speaker. Please add an option to disable this connection sound. If you my posted video, you'll see that it's a different sound.
05-28-2024 05:07 PM
Hi @dbdq,
We're always looking for ways to make you all feel welcome. Your feedback is important to us.
Please help us improve by filling out the feedback form.
Thank you for your honest feedback. This is really helpful.
Brandon.
