11-30-2022 12:19 PM
Apologies if this is covered elsewhere, I haven't found the answer.
I wish to set a number of recurring reminders that will display on my Mothers (Age 91) Google Hub Max screen.
I understand that I can set the reminders in (her) Google Calendar, to which I have access. Do I need to do anything / make any setting changes to her Hub to ensure they actually display on the screen at then correct time on the right day. She is hard of hearing so a visual reminder is necessary.
What does she need to do once she has 'seen' and actioned the reminder to clear it from the screen?
We don't live nearby so I need to do all this remotely.
TIA for any assistance
12-05-2022 05:27 PM
Hi KEVVY,
Setting reminders is one of the most useful features of Google Nest speakers. I truly understand how helpful it is for you and to your mother especially that it's so easy to use and navigate. If you have completely set up your Google Nest display as well as your phone that uses the same account, setting reminders is very easy. However, the Google Nest display can only show one reminder at a time. As soon as the reminder is shown, you can tap on the screen to remove it from the display.
You might want to check this link for more info: https://goo.gle/3ury8JP
Hope this helps.
Princess
12-08-2022 05:29 PM
Hello there,
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
12-09-2022 05:37 PM
Hi Kevvy,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest speakers and we'd be glad to assist you further.
Princess
