12-07-2022 08:49 PM
How can I setup the camera on the Nest Hub Max without QRC code or setup code?
12-07-2022 11:16 PM
Set up Nest Hub Max's Nest Cam
Open the Google Home app .
Touch and hold the Nest Hub Max for which you'd like to set up the Nest Cam.
At the bottom, tap Set up Nest Cam.
Follow the on-screen directions and when prompted, use your mobile device's camera to scan the QR Code displayed on your Nest Hub Max.
This may help you,
Rachel Gomez
12-07-2022 11:16 PM
This may help you,
Rachel Gomez
12-08-2022 06:42 AM
That did help. I appreciate your response!
12-09-2022 12:35 PM - edited 12-09-2022 12:36 PM
@RachelGomez123, thanks for the help.
@Steph5, thanks for posting. Thanks for keeping us in the loop and happy to hear that this has been sorted out. We will mark this thread as resolved. Give us a shout if something comes up — you know where to find us!
Juni
