Hub Max Nest cam showing offline and not working as live feed
Rdianco
Disclaimer: This thread was migrated from our previous version of the Google Nest Community. You can continue to receive updates on your thread issue here or simply ask, browse or more in the new Google Nest Community.
Original poster: Sam Thurlow
The Google Hub Max Nest cam is not showing a live feed in the Google Home app. Showing as off when first going into the cam view and then just a loading sign (as below) when you select live feed. Going through the setting the home monitoring feature is off, and will not stay on when swiped across (automatically swipes back left to the off position).
frances
Hi Sam Thurlow,
Thank you for your message. I am sorry to hear that your Google Nest Hub Max cam is not working or toggling on. I understand your concern and would be more than happy to help resolve this issue. First, I have a quick question.
  • Can you please try to do a reboot and Factory Data Reset on your Google Nest Mini? Are there any improvements?
    • A factory reset will reset your Google Nest or Home speaker or display to its default factory settings.
    • Note: This action will clear your data from the device and can't be undone.
I look forward to your response, thanks for your patience!
This fix did not work for my hub Max. Having the same issue as above. Did a reboot and master reset. Went back through the setup process. And the same exact thing is still happening. Please help.
frances
Hi All,
It's been a few days since we have heard from you. Just checking to see if this issue has been resolved. Feel free to ask any other questions or concerns you have. We're here to help!
GarrettDS
It looks like we have come to a solution so I'm going to be locking this thread. If you have any other concerns or questions, please feel free to create a new thread.
Have a great day.
Garrett DS
