12-21-2023 01:04 PM
I have YouTube TV and sometimes, albeit inconsistently, I can get it to play the local CBS affiliate via local channels. Sometimes it won't play because "the service is not available in my area" or "this app is a paid service." I reset it in the hope of fixing the inconsistent operation but if anything, now it is even worse and usually will not play anything at all except for the rare instance when it will play. To get it to work, I usually say, "OK, Google, play CBS on YouTube TV" and it either plays or it doesn't. I don't see YTTV in the list of video links in Setup. I'm sure the problem lies with me, but I just could use some guidance or some assistance. Thanks in advance for anything you can offer.
12-28-2023 12:33 PM
Hi Driver8,
Thanks for reaching out and letting us know about your Google Nest Hub Max concern. I know how it feels when something isn’t working as it should. A few questions: when did it begin? Were there any recent changes made? Are you getting the same response when you use your phone’s Google Assistant? Also, could you confirm by checking the link below if that is how you did the reset?
Factory reset Google Nest or Home speakers or displays
Juni
01-03-2024 06:53 AM
Juni, the inconsistent operation has been an issue since day one. No recent changes. I've not used the Google Assistant. There is no YT TV Link in my Google Home link settings for the GNHM. I have performed several resets with no improvement. The reset method link is how I performed the reset. I have encountered the same problem at least twice over the past two days. Thanks!
01-04-2024 10:36 AM
Hey Driver8,
Thanks for the details you’ve shared. Which country are you contacting us from?
Keep me posted.
Juni
01-07-2024 10:57 AM
Northcentral WV USA
01-12-2024 11:24 AM
Thanks for the additional info you've shared. We'd be happy to take a look into this for you. Please fill out this Contact us form with all the needed information, then let me know once done. Lastly, could you provide us with your device's firmware version? Check out the steps below on how to get it:
Juni
01-18-2024 01:15 PM
Hello Driver8,
Chiming in-- have you had the chance to fill out the form? Let us know once you're done so we can check it.
Princess
