3 weeks ago
I´m reaching this forum because i have some doubts about the Google Nest Hub. Regardless of which model I might buy, I’d like to know if it’s possible to ask Google to show me, for example, Camera ONE. This camera is from Tapo (TP-Link), as well as other devices I have from Sonoff.
In my Google Home app, I manage all my smart devices, but I’m very interested in buying a Google Nest Hub so that my family can also access and control them more easily.
Thanks!
2 weeks ago
Hi Matias74,
Thanks for posting in the community. I understand you're interested in using your Tapo cameras and Sonoff devices, including your lights, with a Google Nest Hub. No worries, help's here!
The feature you're asking about is supported on Tapo cameras, as long as you're using Google Assistant-enabled or Works with Google devices. Once you've linked these devices to your Google Home account, you can use voice commands to view your specific cameras. This makes it easy for you and your family to access and control your smart home devices. Refer to this article: Stream your security camera using your Google Nest display.
For information on whether your Sonoff devices are compatible with the Google Home app, we recommend reaching out to the manufacturer for the most accurate and up-to-date information.
Melany
