08-16-2025 05:09 PM
I have a Nest Audio when I try to play music it doesnt play the audio. The lights turn on, responds to me, and volume is turned up. I've tried resetting and setup again but nothing works.
08-19-2025 11:41 PM
Hi @Jmlozb7,
Thanks for reaching out to the community. I'm sorry to hear that your Nest Audio is not playing any audio, even though it appears to be working otherwise. I appreciate you confirming the troubleshooting you have done. I'm happy to assist.
To gather the necessary information, please answer the following questions:
I'll be waiting for your reply.
Best regards.
Derick.
08-20-2025 10:22 AM
Thank you! The issue started last Tuesday. It doesnt give an audio signal but the LED light do trigger when I say 'Hey Google'
09-02-2025 12:28 AM
G'day jmlozb, was wondering what the outcome of this was?
My Nest Audio started having issues recently, much the same as yours. Managed to reset it and it worked for a few days then it got completely bricked (doesn't even seem to turn on). Google support said out of warranty, however there seems to be a number of people having issues since the last firmware update.
08-21-2025 09:01 PM
Hi there!
Thanks for your reply. I appreciate you confirming that the issue with your Nest Audio persists even after you've reset and set it up again. It's helpful to know that only the LED lights are working, with no audio playback.
The team would like to learn more about this situation. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
Derick.
