Motion Sense setting is missing on Nest Hub 2
ZC2
I noticed that the Motion Sense option is missing under the Settings menu in my Nest Hub Gen 2. Is this due to the region that I am currently based (Singapore) is not supporting that feature (Motion & Sleep tracking)?
20 REPLIES 20
PijamaCL
Same issue here... Im in Chile
mwndl
Same issue.. Brazil
fung2006
Same issue... Hong Kong
SheppySA
Me too. In South Africa.
roldi
Same issue here in the Philippines.
gbrossi
Same issue in Argentina
gbrossi
So, Google sells products to the whole world through their distributors or stores like Walmart and how is the consumer supposed to know that it's not going to work? Very frustrating...
gauravahuja
Same issue. India.
Azizzeanna
I'm having the same issues - Malaysia
Looneylass
I have same issue but I’m in UK??
are you sure its not a gen 1?
Kique
In my case, it says Gen 2 in the box and everywhere.
djbeach73
I don't have the box & although the s/w refers to nest & have looked at the model number on the base (mine in H1A before the s/n) I can't see "motion sense" setting in settings so I'm suspicious. What's your model number & have you done a factory reset?
Kique
The model number is GUIK2 and the system firmware version is 280498
I did a factory reset and by the comments of other people, it seems that they have applied a factory reset too, but the general consensus seems to be that depends on the country where you are using it.
Yep. I'm sure
Abhijazz
Same here
Kique
I have the same issue. Im in México but i bought it in the US. Does this depends on the place where i use it or on the place from where i bought it?
ZC2
I believed it depends on the place where u used it.
Hey all,
Since this thread hasn't had activity in a while, we're going to close it to keep content fresh. We hope you were able to get the help you need, but if the issue persists feel free to create a new thread, and provide as many details as possible so that others can lend a hand.
Kablansy
I have the same issue. Nest Hub 2nd Gen bought in France with Google online store. I use it in Ivory Coast (Côte d'Ivoire). Very frustrating as I bought it to track ly sleep.
