NEST HUB Max manufactured for a different country
Matty87
My Nest Hub Max, wouldn’t connect to my wifi I get the following error message on my google home app ‘THIS NEST HUB MAX Was manufactured for a different country, and may not be compatible with your Wi-Fi Network’
I’ve factory rest my device, ensured all firmware and apps are up to date.
Any help would be appreciated
David_K
Google Home and Google Nest products are optimized to work best with specific Wi-Fi standards depending on where they are sold. This means if you buy a product in one country, it may not work as expected, or may not work at all, if you try to use it in a different country than where it was purchased.
The first thing to try is to factory reset your device and retry setup. If that doesn’t resolve the issue, there are some workarounds you can try:
  1. If your router is a dual band router and has different network names for the two Wifi bands, make sure you are connecting to the 2.4GHz band and not 5GHz.
  2. Login to the admin page of your router (refer to the manual or the back of the device).
  3. Navigate to Wifi or Wireless settings (the naming of the menu options you see will differ by router manufacturer and you may need to click to go into "advanced" settings to see some options).
  4. If your router is a dual band router and doesn't currently have different names for the two bands, look for an option to turn on different network names for the two bands.
  5. If "Wifi Protected Setup" or "WPS" is enabled, disable it.
  6. Set your Wifi channel/band (channel selection) to a value between 1 and 10.
Google Home and Google Nest speakers and displays manufactured for certain countries cannot connect to Wifi channels above certain frequencies which is why I suggest changing your Wifi channel to between 1 and 10. Checking you are using the 2.4GHz band and not the 5GHz band is for dual band routers and is for the same reason. The two steps are interchangeable for some routers but not for others.
Mlabrador
Thanks for posting.
@David_K, appreciate the help!
@Matty87, I would like to follow up if the troubleshooting provided above worked?
Keep me posted.
Nikki
Azarco
Hey Matty87,
We wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Alex
Azarco
Hello there,
One quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need assistance, feel free to start a new thread in the Community and we’ll be happy to help.
Alex
