06-22-2024 05:32 PM
Hi one of my Nest Audio devices is not booting,
It does not even turn on the lights,
I have tried:
to disconnected and wait for more than 5 minutes, reconnect it and nothing.
to change places with another nest audio, (different room so different plug as well), the one that was dead still dead and the one working continue without problem.
is there any other troubleshooting steps that I can try?
Thanks.
07-01-2024 08:32 AM
Hi MiguelBV,
Thanks for reaching out! I understand your Nest Audio isn't turning on. That can definitely be frustrating, no worries I'm here to help!
Here are some steps you can follow:
I hope this helps! If not please let me know or if you have any other questions, I'll be more than happy to help.
Manuel
