01-21-2023 02:31 PM
I just changed internet providers. the nest hub was previously working fine with the old provider. It will not connect with the new one. I've reset back to factory settings 5 times & unplugged it numerous times. Every time I go through the setup process it does not even list my wifi internet. I've reset my router 3-4 rimes as well.
01-25-2023 04:46 PM
Hey danielbugeja10,
Thanks for reaching out. I know how challenging it is when your Google Nest Hub (2nd gen) is not connecting to your network. I'd love to dig deeper into this. A few questions: how far is your Nest Hub (2nd gen) from the router during set up? Have you tried using a different phone/tablet? Is your network visible to other devices? Do you have another Google speaker/Nest display that is able to connect?
To eliminate network issues, please try setting up your device using a mobile hotspot. Please note that you will need two mobile devices for this setup (one will serve as a router and the other to be used to set up your 2nd gen Nest Hub).
Let me know how it goes.
Muddi
01-25-2023 06:54 PM
Nest hub and audio will not connect no matter what. It’s not far from the router. I have Google chrome cast on a tv which is further away and outside in a garage and it connects fine.
Also another google speaker which connects fine.
01-25-2023 06:57 PM
And as expected the hotspot didn’t work either. When trying to connect the google home app does not even bring up the hotspot or home internet on the list to connect too.
02-01-2023 06:45 AM
Juni
02-02-2023 06:58 AM
Hello there,
We haven’t heard back from you, so I'll be locking this thread in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Juni
01-29-2023 12:32 AM - edited 01-29-2023 05:43 PM
Hi danielbugeja10,
Thanks for the update. Could you tell us when and where you purchased your device?
Muddi
