01-22-2022 05:21 PM
Nest Hub Max camera offline after multiple factory resets and setup. This seems to be happening to numerous people randomly. Its only a few months old.
01-26-2022 07:39 AM
I'm having the same issue, multiple factory resets! I have tried everything, selected every option. it detects when I walk in front of it. "Display isn't available right now" how can we get support on this? I have other google cams that work on it just fine. The Home app camera settings "Home monitoring features" when turned on automatically will switch itself back off immediately. frustrated! please post if you find a solution.
01-28-2022 11:15 PM
Thanks for sharing details about this issue here, and apologize that you have to go through with this issue on your Nest Hub Max camera.
A few questions:
Please try these steps below that may help us fix the issue:
Let me know how it goes.
Muddi
02-09-2022 10:53 PM
Checking in to see if the troubleshooting steps shared helped? Feel free to reply and we're happy to help.
Muddi
02-10-2022 11:27 AM
I tried that several times... turns out I added 2 hub cameras prior to getting the MAX hub. The hub likes to be setup first before you add other cams. I had to create a new home and start over and move all my other devices to the new home... but now I have lost my link to nest aware account, seems the cams are tied to the old Home name.
02-11-2022 03:49 PM
Hey ostenzel,
Thanks for the update. I'm glad to know that your Nest Hub Max camera is now working. The Nest Aware subscription is tied up to a home structure. I suggest that you contact Nest support so they can transfer your Nest Aware subscription to the new home structure.
If you have other concerns about your Google Nest Hub Max, please do not hesitate to update this thread, and we're happy to assist you.
Muddi
02-16-2022 06:03 PM
It's been some time since this thread was updated. Does anyone here need assistance?
Muddi
02-18-2022 01:53 AM
I'll be locking this thread now since I'm not getting a response. Feel free to open a new one if you happen to encounter some issues or if you have more questions in the future.
Cheers!
Muddi
