3 weeks ago
I often watch YouTube TV on my Google Displays but this morning none of them were able to even launch the YouTube TV app. It reports that it needs to be set up and to make sure I'm logged into the same account but nothing has changed since yesterday when it did work. Is this due to the Google Assistant to Gemini transition?
3 weeks ago - last edited 3 weeks ago
In that case, I had to contact youtube tv customer service . Honestly, I didn't expect them to answer so quickly: the operator explained in detail what had happened and helped me set everything up. Since then, I've realized that sometimes it's easier to ask specialists right away than to spend hours trying on your own.
3 weeks ago
3 weeks ago
Bonjour 👋
Avez vous assuré toutes vos mises à jour sur les 2 enseintes que vous décrivez ? Pour ce qui est de la transition, normalement cela n'a pas d'impact dessus sauf si Gemini a mal compris votre message.
Je reste à disposition
Cordialement
This week, YouTubeTV suddenly stopped working on ALL of my Nest hubs.
Me: "Ok, Google. Play NBC on YouTubeTV."
Response: "It either isn't available or can't be played right now."
I power-cycled the Nest Hub Max, and it still didn't work. YouTubeTV won't launch on any other Nest Hub. It works on Chromecast and the Google Streamer on the TVs, but not the hubs. My account is in good standing and connected to my Google Home account.
I searched these forums but couldn't find a definitive answer. What is going on?
2 weeks ago - last edited 2 weeks ago
I was able to fix my issue. I moved to the next town over with a different zip code. I'm still in the same viewing area, but it appears the zip code makes a difference.
Check your settings for your viewing area.
