Nest Hub No Longer Streams Camera Feeds by Automation
KUNTATA
Hi all, I have set the automation that if my front door Philips Hue sensor senses the motion, it will stream the nest outdoor camera to various nest hubs at home, then after 90secs will display the clock to stop the stream. It worked pretty well before.
But in recent few months it stopped working and I couldn't figure out what's wrong. The starter is fine because I still can see after 90 secs the clock will be shown on the nest hubs, but only no live feed of the nest outdoor camera. I checked here and saw a post said changed "Show me the Front Camera" to "(Show me)/(Show) the Front Camera on XXX Nest Hubs". But when I did that the nest hubs say "sorry I don't understand". I tried to changed the words a bit but no luck. Is there any solutions to that? Thanks a lot.
7 REPLIES 7
tajennifer
Hi KUNTATA,
Thanks for reaching out. I understand you're experiencing an issue with your Nest Hub that it's currently streaming camera feeds via automation for only 90 seconds before reverting to the clock display. Please don't worry; I'm here to help you with this.
To provide you with the best solution, I'll need a little more information:
  • What is the exact model of your Google Nest Hub?
  • What are the models of the cameras you are using?
  • What troubleshooting steps have you tried so far?
Please keep me posted.
Jenny
google nest hub max
google nest hub 2nd gen
Nest Cam (outdoor or indoor, battery)
Nest Doorbell (battery)(Connected with power)
I tried to remove all devices and add them back but nothing works
Using the voice command works fine, but with automation nothing works/ And the strangest point is it was working so well before this happened, but I didn't make any change on the script or devices  or WIFI.
Thanks
Homeautogeek
Same issue here, really annoying, using the voice command works fine but automating the command no longer works
Same. Really annoying
tajennifer
Thank you for reaching out and for providing this information. I understand the inconvenience this may cause. We appreciate your feedback. We're constantly working on improvements, and your input helps us shape future features.
Jenny
KUNTATA
So I provided all asked details, and the final answer I received is Thank you everyone... ?
siking85
I also have the same issue! This is typical google! You've broken yet another working solution
