12-14-2023 10:33 AM
I have been using Sirius XM with my nest hub for years. All of a sudden it stopped working.
You can request to play something from Sirius XM, and the Hub obliges... "Streaming XXXX on Sirius XM..."
The screen then shows that the hub switches to Sirius XM but just before the player launches you can see (VERY briefly)an alert that reads:
"config-failed :0. Could not retrieve receiver configuration, please try again in a few minutes"
I have tried re-linking my Sirius account, unplugging the hub and even the entire wifi network. Nothing seems to fix it.
The hub functions properly on all other fronts (Spotify works etc)
Anyone have any advice here?
thanks
12-15-2023 06:39 AM
Thanks for reporting this to the community. The team is aware and is currently investigating this issue. To help the team further look into this, kindly turn on device usage data and crash reports. Reproduce the issue by asking your Google Nest speaker/display to play a station on SiriusXM, then give it a voice command to send feedback using the keywords “GHT3 Sirius XM stop streaming."
Please keep an eye on this thread for further updates. Sorry for the inconvenience, and thanks for your patience.
Warmly,
Alex
12-15-2023 03:42 PM - edited 12-15-2023 04:44 PM
Welp. New bad behavior. The workaround still works but...
When I launch SXM directly on the G device it behaves as expected but only for a few minutes. At that point it stops the channel playing and offers up a variety of video options. 😠
I guess this should be a new thread here but it also it feels like a hangover from the original handshake/authentication problem.
New thread for new bad behavior: https://www.googlenestcommunity.com/t5/Speakers-and-Displays/Sirius-XM-behaving-badly/td-p/563062
12-15-2023 05:07 PM
Miraculously it started working again. Gotta love technology!!!
12-15-2023 05:30 PM
My siriusxm feed is now working correctly.
12-17-2023 03:58 PM
Hello everyone,
Thank you for your patience. I have duplicated this thread as we have noticed a similar trend of this issue among our users. Our team is already aware of this situation and is actively investigating it.
In the meantime, we kindly request you to follow the steps provided on the "Recommended Answer" and share your feedback. Your cooperation will help us in further investigating and resolving the issue.
Muddi
12-19-2023 08:23 AM - edited 12-19-2023 08:33 AM
Any updates Muddi? Are the dev teams at G/N & SXM making any progress?
Bad behavior update:
12-15-2023 03:48 PM
Check this thread:
It describes the problem and temporary workaround.
12-18-2023 11:44 AM
Issue is still going on in the US. It will start on the Google Home hub then play for 20 to 25 minutes, then stop and show a video playlist recommendations for you. Asking it to start playing again, it plays for about five minutes and does the same thing.
12-24-2023 06:41 PM
Wasn't working at all about a week ago, and after about two days it started magically working again (I'm guessing Google pushed out a fix) but now the streaming cuts out randomly, sometimes as quickly as only a couple seconds after starting. I will tell my smart speaker to stream a SiriusXM channel, it acknowledges and begins the stream, and then about halfway through the song the streams ends abruptly. It does this repeatedly every time I restart the stream. About once out of every ten times I restart it I'll get lucky and it'll stream for upwards of 15 to 30 minutes but it always eventually cuts out. This has always been a problem dating back years for me but at least it only stopped after a few hours; seems like since whatever changes were done recently this problem has increased exponentially. Very frustrating.
12-24-2023 06:47 PM
Try starting it from your phone/tablet then cast to your speaker. This seems to work and not crash out after a song or two.
12-09-2023 11:27 AM
SiriusXM just stopped playing on my Google Home. I have both a nest hub and a mini. When requesting a SiriusXM station I get the response "Something went wrong. Try Again." This issue just cropped up yesterday. I ahd the same issue months ago and then it magically fixed itself.
Is this a software update issue? Is anyone lookinginto this?
12-10-2023 05:11 AM
This just started happening to me as well. Two days ago. I’ve factory reset my nest and the problem is still happening. Thanks for posting. Hoping we can escalate this.
12-13-2023 10:32 AM
Thanks for posting—let's get this sorted out. Have you tried asking Google Assistant on your phone to play SiriusXM to see if it works? How about casting from the SiriusXM app to your Google Home devices? Try to unlink and relink your SiriusXM account, and then reboot your Google Home devices. Let me know how it goes.
Alex
12-13-2023 05:06 PM
Thanks. The issue resolved itself, just like Edbank mentioned below.
12-14-2023 10:43 AM
Glad to see resolution for others.
This just happened with me in Canada. I unlinked/linked my SiriusXM account in Home, rebooted devices, etc. I can stream other services and cast SiriusXM from my phone. The one additional bit of information I can provide is the error message that appears briefly on my Hub:
"config-failed : 0
This may auto resolve for me as well but so far, no joy. So casting it is for now.
12-14-2023 03:49 PM
This just happened to me, even though it was working earlier today. Same error message you got. This is extremely frustrating.
12-24-2023 10:21 AM
Siriusxm starts and then suddenly stops! All the suggestions DO NOT WORK! Google needs to work with Siriusxm and find a solution with this. This has been a problem reported all over the internet. Please fix it.
12-24-2023 10:37 AM
I absolutely concur. This same problem surfaced over a year ago.
12-13-2023 11:35 AM
The issue resolved itself today with no interaction on my part.
12-13-2023 05:07 PM
Just checked my hub and it played with no issue and no interaction on my part either. Thanks for commenting again, or else I would have rebooted and unlinked for the millionth time this week.
12-14-2023 10:27 AM
We’re glad to hear that this has been sorted out! Thanks for keeping us updated. Should you have other concerns about Google Nest devices, you know where to find us. We’d be happy to help.
Alex
12-14-2023 03:50 PM
Hi Alexa, please see DaleN’s comment above. I just received the same error message, even though I was able to play music earlier today.
12-14-2023 04:56 PM
For more info on the today's issue see Community Thread:
"Nest Hub and Sirius XM not working : Config-Failed??"
12-24-2023 07:52 PM
Hello everyone,
Muddi
01-05-2024 02:56 PM
Any updates as this still isn't working. Very frustrating!
12-18-2023 10:31 PM
To reiterate, the problem only resolved itself for one day.
12-22-2023 11:06 AM
I have been having the same issue, two nest mini speakers. Sirius XM will play for several songs and then stop. Sometimes it will drop immediately or during the first song. I have rebooted both and unlinked and relinked Sirius XM. Still have the same problem. It started about two weeks ago and would play about a half hour before dropping. The last few days it has gotten progressively shorter as described above.
12-24-2023 10:46 AM
This is not fixed - I am still having problems. Sirius XM will only play 20 seconds and then stop. I have linked/unlinked rebooted and sent a feedback. After I sent feedback I can't play Sirius from my phone now either. PLEASE FIX THIS
01-26-2024 06:55 PM
I am having the same problem. Unlinked and relinked several times. But I get "Playing xxx on Sirius XM" and then SILENCE.
12-15-2023 09:33 AM
Same Sirius XM problem started yesterday for me. None of the recommended fixes will work.
12-15-2023 03:00 PM
After fixing itself, mine went on the fritz again last night
12-18-2023 09:44 AM
Happening to me. Starts streaming then after several minutes it stops. Help!!…
12-22-2023 09:11 AM
Same here. Worked a week or so ago for a day or two, now back to stopping streaming after a few minutes. Only seems to be an issue with SiriusXM.
12-15-2023 09:53 AM - edited 12-15-2023 09:54 AM
I can no longer play SiriusXM directly from the smart speaker. It was working fine as of 2 days ago. When I request to listen to anything on SiriusXM through the smart speaker the assistant voice responds with "now playing Sirius XM" as it normally does however after that it's silent and there is no music or radio. I have tried all the troubleshooting steps the advisor suggested. Unplugged all the speakers, replugged them, reconnected them to wifi. I also unlinked and relinked my SiriusXM account several times through the Home app. I even deleted the home profile and re created the home through the Home app. The same behavior still exists. The assistant language is set to English US.
The only way to listen is to cast it directly from the SiriusXM app to the smart speakers. However, requesting the speaker to play the channels no longer works. This is irrespective of channel being requested on SiriusXM.
Again the speaker responds that it will play the channel that I requested however the channel never comes on. Just silence. Again, it was working fine as of two days ago.
12-15-2023 10:14 AM
Exact same problem the last two days. It's happened before and resolved itself when Google realizes it's them and not SiriusXM
12-15-2023 10:22 AM
Exact same problem here too! Please, Google, notice and resolve this!
12-15-2023 11:04 AM
Same! I found a bunch of posts from this same thing happening in late April, but appears to have been fixed by Google within a day or two. Google, please fix!
12-15-2023 11:06 AM
I am having the exact same problem. This started 2 days ago. I never had an issue before trying to stream Sirius XM thru my google home speakers.
12-15-2023 11:23 AM
Same here. Was working a few days ago and now it is silence....
12-15-2023 11:27 AM
Same here. Not sure but Sirius has changed it's app on the 14th.
12-15-2023 11:42 AM
I have the same issue and tried all the recommended actions and still unresolved. Can play by casting from my phone to speakers or Spotify and YouTube Music. Google please fix or send info on how to fix.
