08-18-2025 09:28 PM
Ever since I had to change my home's gateway, I have noticed that my device goes offline and has to reconnect. Randomly, it goes into a set up screen and then Connecting screen.
I'm also noticing that when I try to tell my assistant that I'm going out of that I'm home, he takes his good old sweet time or doesn't respond at all, going back to what he was doing before. (Example, I tell him that I'm home and he refuses to acknowledge me and my command and stop playing the talk radio station that I leave on for my cat or dogs when I'm pet sitting for my brother. It's frustrating to the point that I cursed at him and sent in feedback.)
I did have to reset my Nest Hub to reset the wifi network. (I had to reset all of my Google products to fix that issue.) Could someone please explain what Mr Google Man's problem is and how can I fix this to make it was it was before? (That is my Nest Hub's name on the wifi network.)
08-19-2025 05:02 AM
Do you have a mesh network for your Wi-Fi?
08-19-2025 05:10 AM
No mesh that I know of. It's a gateway that has 3 bands, 2.4 ghz, 5 ghz, and 6 ghz. And the gateway is nearby... Maybe 10 to 15 ft away.
08-22-2025 08:11 PM - edited 08-22-2025 08:19 PM
Hi @Rushfan3,
Thanks for reaching out to the community! I'm sorry to hear that you've been experiencing issues with your Nest Hub, specifically that it goes offline or is unresponsive to commands. I understand how frustrating this can be, and I appreciate that you've already tried some troubleshooting steps! I'd be happy to assist you with this.
Before we move forward, I'll need some more information from you:
Once you have this information, I'll be more than ready to assist you!
Debora
08-23-2025 09:43 AM
I am not seeing which model I have but I known it's a 7 Inch screen with the built in speaker and camera, so I'm guessing it's 2nd Generation. It was updated to Fuschia, which that version is 27.20250422.103.3600, Chromecast Firmware version is 3.77.487224, software version is 67.86.11.770747979. The app on my phone is up to date, with the last update being done July 30, 2025.
My network isn't separated. I did have an issue with connecting to the network back when I got the gateway in early July, as my network information was supposed to transfer to the new gateway, but it did not, so I reset the entire Hub to allow for my network to connect as it would not allow me to add one. I know that it has run on the 2.4 GHz band in the past, but have no way to separate the bands at the moment, though I have plans on doing as such soon if it's possible.
If I knew how to trigger an update to it, I would try it.
08-29-2025 09:27 PM
Hi @Rushfan3,
Thanks for the details! They are really helpful. Let me share some troubleshooting steps with you. Please follow them and let me know how it goes:
Keep me posted!
Debora
